TwinTurbo.NET: Nissan 300ZX forum - Re: No
Re: No
Compiratenew
on June 06, 2017 at 12:28 PM
No
posted by emnm187
on June 06, 2017 at 05:21 AM
If it leaked out, isn't there an opening?
Does an AC recharge require a vacuum?
Stokens (AR)
18:32:11 06/05/17
Re: Does an AC recharge require a vacuum?
Compiratenew
18:55:05 06/05/17
The manifold gauges should give you an idea...
Jehannum
11:00:00 06/06/17
Re: The manifold gauges should give you an idea...
Compiratenew
12:27:09 06/06/17
The Gauges will give you an Idea of How Low it is
Cjw3
15:17:13 06/06/17
Only if there is less then about 5 PSI when you start (n/m)
Cjw3
22:38:23 06/05/17
No
emnm187
05:21:11 06/06/17
Re: No -
Compiratenew
12:28:30 06/06/17
Yup! and if it sat awhile the system has to be vacuumed>>
ZUL8TR
13:18:17 06/06/17
Vacuum is to remove air and moisture
emnm187
07:41:44 06/08/17
Re: Vacuum is to remove air and moisture
Compiratenew
19:21:56 06/08/17
It was Made and assembled on Wed. In my 1992 Z >>
ZUL8TR
04:54:21 06/11/17
